Upgrade Tilt Steering Column to more Modern Look
MadOgre
NA
NA
NA
NA
NA
Has anyone ever replaced the tilt steering column components ( shift lever, ignition switch, tilt handle and turn signal to the 90s black hardware.
I have an 84 automatic tilt column and was thinking of redoing the dash a dark grey with black trim and thought that it would look cool if I could change out the steering column hard ware to the newer black stuff too.
I already have a black turn/wiper/cruise lever and grabbed a black tilt lever the other day which has the same threads, so im just wondering if the shift lever and ignition tumbler will swap in also ?
One of these days I have to rebuild the tilt column anyways so thought I could switch the tumbler at that time.
MadOgre
NA
NA
NA
NA
NA
Oh cool. I figured it would but you never know.
I think its a good look to go with a black bezel and trim. Ive got the smaller wheel out of a newer blazer already, that way I don't have to mess with the chrome/aluminum bezel.
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
I will be doing this with my current resto project, I think it all looks better when the key, signal lever and tilt lever is factory black.
MadOgre
NA
NA
NA
NA
NA
Yes me too. You will probably get yours done long before I even think of getting to this one!
Looking forward to seeing some pics when you get it done.
Also the shift lever knob is a different shape. I don't think it would match the older style wheels very well though. But with a newer or after market wheel I think it would look sharp although I have never seen it done.
rgorma01
