Unknown engine noise help
motohunter4
US
Hunter
+1 on the stethoscope.
Sent from my LGLS755 using Tapatalk
Maybe it's the angle of the pictures, but that appears to be the wrong fan shroud? The fan looks inset a bit far.
78C10BigTen
pennsylvannia
C10 BIG TEN
The fan is in a bit... it may be the wrong fan.... the motor has been swapped twice but if i recall never the shroud or rad.
78C10BigTen
pennsylvannia
C10 BIG TEN
As posted earlier about the blades looking backwards, the fan blade ring may be mounted in the opposite direction but when runnin the fan does blow air back over the water pump area of the motor. Idk honestly as ive done so many motor/trans swaps outta necessity.
Rusty Nail
Rusty
350sbc
So as i sit here in the running truck on my break at work, it made a liar outta me. Its not doing it now. Maybe it needs to be fully warm to expose itself...:shrug:
If your mailing address is correct? No worries, we'll send a bill. ;)
I heard water pump and front bumper.
o_O
Does the bumper rattle? Cuz THAT is hella annoying!
Youknowwhatimsayin?
78C10BigTen
pennsylvannia
C10 BIG TEN
Problem solved. Lol
Just kidding. Maybe the bearings need to wa rm up before they start making noise.
Drove it from work to the beer store and all the way home, park it running and no noise.... duh fuq?!
78C10BigTen
pennsylvannia
C10 BIG TEN
o_O
Youknowwhatimsayin?
Says every garage.... lol
78C10BigTen
pennsylvannia
C10 BIG TEN
o_O
Youknowwhatimsayin?
It does not rattle.
Red Rex
Middle Ga
K 1500 4 WD shortbed
Great lubricant!
78C10BigTen
pennsylvannia
C10 BIG TEN
So to update, after a few good days the noise reappeared on my way home tonight. I popped off the fan belt so the only thing turning would be engine and ps pump, noise still there. I have a sinking feeling shes got some sort of of bearing issue. If it still does it this weekend ill pull all the belts and isolate it closer.
johnalen76
