Turbo 35 C
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
This transmission does have a TV cable!
Thanks
If its a th350c (or th350) that's your kickdown cable for passing gear. Often confused with a 700r4 TV cable.
Rick Smith
Florida
Silverardo
Thank You! One more question, can i eliminate the Tip In Switch that's on the passenger side of the trans?
Thanks!!
Rick Smith
Florida
Silverardo
Here's the two connections on the trans. the blue one is on the left side and the black one is on the right side . I believe the black one is the tip in switch?
Vbb199
Salisbury NC
Vince
Yea, you no longer need the plug by the cooler lines.
Also, that's definitely a th350c
Referencing from the cconverter to the tailshaft (or right ti left in your picture) on a 700r4, the dipstick comes first, then the TV cable.
On a th350, the kickdown cable comes first, then the dipstick.
You definitely have a th350c
Please post pics of the pan so people can know what you are actually working with. Its been asked repeatedly on this thread. If you can post pics of the connectors, why not actually identifying pics of the trans itself?
Vbb199
Salisbury NC
Vince
At this point, just post a pic of your own transmission, Eric
Turbo4whl
Downingtown, PA
Wayne
Just to be clear, the long tail shaft TH350C and the 700R4 with the short tail shaft (two wheel drive) are less than 1/2"different in length. The body of the 700R4 is longer.
Vbb199
Salisbury NC
Vince
This is what I was referring to. Forgive the lousy artwork... i did that on my phone
haha, I must have been posting at the same time you got the identification.
and the drivers side 4-prong connector makes it a "C" version with the lockup converter.
Vbb199
Salisbury NC
Vince
The input shaft also has an o ring on it as opposed to no o ring on the non-lockup variation, there's some other things, but I'm not a pro.
johnalen76
