Transfer case
pmehringer001
Indiana
Paxton
V20
I have a 1986 K30 with 6.2 diesel and th400 transmission. I believe it has a np208 transfer case but I am wanting to put a np205 in it. Mostly because it’s heavier duty and I would like to twin stick it as well. Are they the same bolt pattern to the transmission? Same spline count? Length? If not what are my options to do to use the np205?
mcarlo86
ND
Suburban
If it is a true K30, it should have the 205 already unless it has been swapped out.
whats the shifter in the cab look like? and does yours look aluminum? a k30 with a 6.2 and a th400 SHOULD be a np205 already
a round pattern np205 is needed which is rare (taken up by rveryone) is what it originally would have come with
NP208
NP205
pmehringer001
Indiana
Paxton
V20
The shift pattern is
2H
4H
-N
-4L
2H
4H
-N
-4L
strange, someone put a np208 in your cucv unless 1 ton cucvs had them.. which i could of swore they did np205
np208 arent bad but they arent the best either. since its a 1 ton who cares aboutu the weight and quieter aspects of it?
But iti does have a nicer ratio in 4lo
mcarlo86
ND
Suburban
I think the lower 4Low gearing might be why the military used 208’s in the CUCV’s.
pmehringer001
Indiana
Paxton
V20
Ok so it’s confirmed a 208, I’m pretty sure I’ve heard they all had the 205’s in them as well which is why I was confused it had a 208. But are they interchangeable? I’d like to use a 205 so I can twin stick it but if it’s too big of a pain then I’ll do it later on when I redo it.
to my knowledge you just need a round pattern np205 which .. is probably the hardest part lol. @bucket does this seem right? the th400 and shaft should not be an issue i dont thinkm the adapter I think is the same (well, im not sure if thats an adapter as much as it is a mount )
Stickman
