Trans Linkage parts
Ken B
indiana
ken
Sorry hard to get a pic. I am trying to reinstall the trans linkage. the cotter pins/hair pins are easy enough to find, but the spring and coned washer to keep the spring in place....any ideas where I can find these items? My big feet smashed the spring
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Are you talking about the spring that keeps tension on the pin clip?
Spring wave washer + flat washer, there's a bazillion of them on Amazon or I'd bet Doorman or someone sells them in the little "Help" section of the parts store.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
@Ken B we had the same problem and could not find everything so we went with the Lokar ACA-1804 linkage. Easy install and works well.
Randy
CalSgt
CA
Casey
Randy
Ken B
indiana
ken
interesting, i will look into it.....
Looks like it may be some kind of tube nut?
I believe the factory linkage is designed so that it is less sensitive to the engine/trans torquing over, as well as chassis and cab movement. That goofy swivel rod with hook end arrangement actually serves a purpose. The spring and plastic cup are available new, but I don't recall who sells them.
Looks like they are all over Ebay too.
As an eBay Associate we earn from qualifying purchases.
Randy and Easton
Randy
C-10 LWB
It does but that is what goes on the shaft that allows the Lokar to connect. Really deceiving looking but works flawlessly
Randy and Easton
Randy
C-10 LWB
See, I know we searched for quite a while… this is what we get for not asking the simple questions here first. I really try not to bother y’all with the little stuff so ya’ll don’t block me and start calling me names………
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
I hear ya
I was looking for 3.5 speaker enclosures. Couldn't find them. Until reading here lately.
If you search speaker pods nothing search speaker baffle and bang there they are.
So that knurled sleeve fits the flat spots of the shaft on one side, and then receives the tube nut on the other side to hold it tight? Kinda neat. I can see where that adjustable lever arrangement would be very useful for a wide variety of cable shifter installs in a crap ton of GM vehicles.
Turbo4whl
Downingtown, PA
Wayne
This reminds me back when I replaced the rubber cab mounts in my '82. Looked at everything I thought. Took the fan off, popped off the distributor cap, brake line clamps to the frame and maybe some other items? Loosened all the bolts, jacked up the passenger side and slipped in the mounts, bolts back in loose. Jacked the drive's side, did those and tightened all the bolts.
Was a day or two later, I went to shift the trans to low gear, would not go. Yeah I bent the shifter rod, actually stretched it straighter. Not to hard to fix but just a reminder, you need to look at everything.
Nelsonic
Louisiana
Scott
V3500 Crew Cab
Transmission Shifter Lever Linkage Repair Kit Steering Column Cross Shaft Bushing Spring Fits for 1967-1988 GM Chevy Olds Buick Pontiac Replaces 1377083 15538092 1380549 https://a.co/d/22Ljhot
As an Amazon Associate we earn from qualifying purchases.
Todd Lemon
