Sgt Gus
- Aug 2, 2023
- Texas
- Mark
- R20 3/4 ton
- 454ci/7.4L
Okay, so having high idle after warm up.
After using winaldl and checking base mechanical idle, iac reset, iac reset and ck base idle...
TPS goes from .59 volts (multimeter) and winaldl to .76 area after warm/hot.
CTS gets to 176-178°, which coensides with Lazer temperature Thang +/- 2° at sensor.
I have 180° Stat and CC radiator with 7 blade fan.
FYI, head gauge will hit 210°, have 9.5 compression
Map will range from start 28-36 kpa
O2 ends up at around .8, rich, rich flag
Fuel psi 12-13 and I backed it down a 1/4 turn
IAC, well yes Lol. Start @ 98 @1375rpm, 62 @ 800rpm, then around 80 for 900 and 950rpm.
TMI?
Ordered a TPS std motor that looks identical.
Question: You agreeing with assessment for potential TPS issue? It didn't used to do this, and seemed to slowly become an issue.
TMI?
