Tow a 5th wheel camper trailer with bed mount hitch ?
Moderator
They also make gooseneck conversion kits for 5th wheel campers, if you choose to go with a gooseneck ball in the bed. There are advantages to going that route as opposed to a 5th wheel hitch. Besides the fact that most non-bumper pull trailers are a gooseneck style and not 5th wheel, if you go with the B&W turnover ball, you still have full use of your bed without having to remove and store a big bulky hitch.
1973c10
Don
Is the trailer 5th wheel or gooseneck ?
I pull a 26ft 5th wheel trailer that is about 7000lb
with my 75 3/4 ton 454 and a th350
I have Pro Series 5th Wheel Hitch with rails in the bed
the rails bolt to the bed and to the frame with frame brackets
I don't think I would bolt it to just the bed ,, frame brackets are cheep and aren't too hard to install.
The tongue weight or ( hitch weight ) is 1180 on mine
Crusader fixer
P30
Diesel
Good information above, couple of thoughts.
First, you will be much happier with a center mount trailer hitch over a bumper mount. The weight distribution is better and the effect of sway, crosswind or semis is much less. A bumper pull gives the leverage advantage to the trailer.
Before spending your money on a hitch check out Rigid Hitch. They have a wide line and provide good equipment, prices and service.
www,rigidhitch.com
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
BW makes a great 5th wheel hitch, but expensive, 1600.00. It is under the bed with a 4" hole where the ball goes through. The ball can be turned upside down when not in use for full bed usage. The 5th wheel mechanism fits onto the ball. I installed 5000 lb. air bags and a compressor that automatically adjusts ride height, no gages in the cab, been on two years and nary a problem. Slide in a camper, automatically aires up, take it out, airs down, fantastic. Use the ball for gooseneck, use the hitch for camper. My preference? like the bed for putting stuff in, but tows well with a fifth wheel.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
First off, I want to thank all of you for the input and information regarding the towing situation and my truck.
I can't find any holes in my frame from where a correct mount would have been.
And there won't be any towing done now since the whole situation changed regarding buying the camper I wanted.
But I do appreciate all the info on how to do it right and safest.
I had plans to buy the camper and leave my remote off grid cabin and relocate close to the city for urgently needed health care since travel from here is so difficult and expensive.
The credit union I have been with for MANY years where I tried to float a small loan (5 grand is peanuts in this day and age) to buy the trailer acted like i was asking for a few million dollars so that all fell through.
Yes, I am pissed at them, when did customer loyalty go out the window ?
I am going to the city tomorrow for biopsies and not looking forward to hear the results, but I don't expect good news.
You guys have always come through for me when there was something I needed to learn about, and this site has the best bunch of loonies and screwballs it has been my honor to hang out with on a forum.
Carb'ed Vortec 350
Hearing you describe the BS you go through to live where, and the way you do, definitely made me rethink moving to that general area.
Praying you get good news
Raider L
Shreveport, LA
William
@mtnmankev,
So what's on the trailer hitch, a gooseneck or a fifth wheel hookup?? Unless you change the trailers hitch out I guess you use what you got, or change it out to save money and secure the load better.
rgorma01
