touch up paint!
86chevyk20
Buffalo
Liam
Hey guys qucik question,
so i painted my k20 this past summer it was my first paint job and it came out "good" i can see someplaces i should of spent more time sanding or filling but i dont want to do it again and press my luck.
My question is, from aligning doors and fenders i nicked the edges alot down to the primer.
Would some touch up singlestage that i had mixed of the proper color work fine for covering those up?
Thanks
Liam
chengny
I guess it depends on how high your standards are - and how deep the divots are.
If the primer is still intact, the color should build up after 2-3 coats. If the primer came off with the finish however - it's probably easier to use either a couple of coats of high build primer (or a thin coat of filler) first.
You went this far - might as well do it right. You are going to be looking at the results for a long time.
86chevyk20
Buffalo
Liam
what i really would love to do is repaint the whole truck because i missed a few dents and those chips, but in reality ill probaly just touch them up.
It was my first paint job ever and i am happy. i just wish i did better and didnt screw the door ends and fender ends up
Kipps5000
