To PCV or not to PCV
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
What's your opinion on PCV, and does really extend your engine life? And more importantly does it Impove you HP?
My opinion, I don't know that's why I'm asking!!!
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
If I understand the PCV system correctly, it uses engine vacuum to pull crank case air pressure from the crank case. This pressure is counter productive to piston movement. That’s why race engines have vacuum pumps to create negative pressure in the block. In typing this I’m sure the PCV system has more to do with emissions crap then anything but negative pressure in the crank case is good positive not so much. Also if your system isn’t working properly oil can shoot out of the dipstick. Lol @RustyPile or @74 Shortbed could probably explain it better.
74 Shortbed
PCV system is a closed system, for it to work properly it also needs a hose from the valve cover on the opposite side to the air filter housing, manifold vacuum pulls air from the crankcase through the PCV valve into the engine, when vacuum goes away the valve closes and venturi vacuum takes over and pulls air from the other valve cover, this way all crankcase air goes back into the engine instead of the environment, and yes it is the first emissions setup, anyone remember the old draft tube spewing **** all over the place, not quite EPA friendly, lol
74 Shortbed
Seen that, seems like a pretty good setup.
Iowan
Iowa
Calvin
K1500
350 crate
Do I need it?
Iowan
Iowa
Calvin
K1500
350 crate
Not mandatory unless you have to have emissions inspection, but it helps keep things clean..
Emissions........:banghead::biggun::boxed::disgust::doublepuke::Frustrated::Rant::Rant::Rant:.....I hate those stupid things!!!!!! Thankfully they don't require that here.
does anyone truly believe in global warming?
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
PCV also helps the oil last longer by sucking all the impurities out of the crank case. Those impurities are mainly what gets past the rings - exhaust. How long do you think good clean motor oil is going to last if you're blowing exhaust onto it all day? Ever see a buggered tail pipe allow the exhaust gasses to corrode the paint off the fender? Sucking that crap out of there is good for the oil; it's good for the engine.
It also, like almost all emission control devices, shuts off when you need full power at wide open throttle.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
PCV is not necessarily and emissions device. They way they are set up now is more environmentally friendly in that you are not venting your crankcase to atmosphere. I believe a properly functioning PCV system is important to an engine but I dont like the idea of sucking in crankcase vapors and oily residue through my intake. I would run a catch can.
74 Shortbed
PCV is not necessarily and emissions device. .
It was when it first came out, it was to prevent all the vapors and oil residue from going out the draft tube in the air and on the road..
I think there are some good points here for both sides. If I were revamping my emissions setup, I'd keep the PCV and the EGR, at least on an ECM vehicle. No EGR if it was a non-ECM vehicle. The only one who I actually value its presence is the charcoal canister. I don't like the smell of gas vapors lingering around my vehicle, and its very maintenance free if you don't overfill your fuel tank. The rest of it can go, especially the smog pump and all those little switches and valves.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I believe in global warming. Every spring when the days get longer the climate warms up. By June it's freaking hot out.
chubhub6969
