Tire fitment
Doug80
Chicago
Douglas
There is probably been ask a million times but truck currently has 31 by 10.50 on stock 15s. Could I run 32 by 11.50 on the stock 15s? Without rubbing? Truck has no lift kit or anything.
MadOgre
NA
NA
NA
NA
NA
The 32" is not a problem. The 11.50 on the stock rims might be an issue. You may need some non stock rims with a better off set. That being said how much room is there now. if you check your clearance now just add another 1/2" in side width and height and visually imagine the tire being that much bigger while you cycle the steering back and forth with the truck on some jack stands. Like I say the height is absolutely not an issue
Doug80
Chicago
Douglas
Hm ok then thank you very much!
77 K20
Montana
K20 5" lift
HT383 fuel injected
I had 32x11.50 tires years ago on my full size blazer. I had the stock rally wheels on it (15x8) and the tires fit them well.
Doug80
Chicago
Douglas
Got any pics?
77 K20
Montana
K20 5" lift
HT383 fuel injected
I looked around a bit but haven't found them yet. I had the blazer so long ago the pics of it are on film and are in one of many boxes. Someday I'll organize them into photo albums.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Offset tends to be the issue as always. You will more than likely have rub when turning and compressing suspension.
Doug80
Chicago
Douglas
So stock rally wheels on 35 12.50 with 4in should clear if not with them with some small trimming?
MadOgre
NA
NA
NA
NA
NA
They will fit fine but will rub and bend your front fenders
Doug80
Chicago
Douglas
Aw lol that's just about the only metal that's not rusted Hahahaha no biggy tho. Thank you for all your input!
83kid
Massachusettes
I got 33's by 12.5's on 15x10 rim, with a 4 inch lift clears no problem so matter how far it flexs or i turn, 35s would work for sure just it might rub or get really really close when your turning and flexing
tweeter68
