Timing problem
Uncle Larry
Grove City, Ohio
Larry
I am working on a 1986 C20, 4.3, carbureted, HEI w/ coil in cap, auto. I am trying to install the distributor and can't seem to get the timing right.
Problem #1; there is no timing tab on the engine block. Looking at the front of the engine and working clockwise, where should the timing mark on the harmonic ballancer be? 12:00? 1:00? 2:00?
Problem #2; Where is #1 on the distributo cap? Looking down at the distributor cap and working clockwise is it the first terminal past the wire connection for the coil or the second?
All input is appreciated,
Uncle Larry
I think the timing tab on a 4.3 is supposed to be at the 12:00 position.
astutz
