timing chain
Gsub
Belgium
Gert
Suburban C10
is it possibel that my chain ia making noise by cold start , and when the engine is hot the noise is gone ? can inadjustbthe chain, or must i replace the chain
gert
firebane
Calgary, AB
Curtis
Sounds like either an exhaust leak or a lifter issue.
Gsub
Belgium
Gert
Suburban C10
how can i know it's a lifter issue ?
350runner
tx
Ceasar
Bud that sounds like a loose bolt big-time.
Or a collapsed lifter...
Gsub
Belgium
Gert
Suburban C10
what do you mean with a loose bolt?
is it normal when the engine is hot , the sound is gone ??
it runs great , and sounds good when the engine is hot ???
Skweegle89
Oklahoma
I didn't watch the video, but if it is an exhaust leak, it would explain why it goes away when it warms up. Things expand when warm. There are a couple different ways to check for a leak, but I don't recall exactly which products to use and I don't want to tell you to dump the wrong thing down your carb, but somebody will know and chime in.
350runner
tx
Ceasar
Just sounds like it. Probably a lifter tho. What oil do you use?
DoubleDingo
Right where I am
Bagoomba
The one I've heard of more than once is Marvel Mystery Oil. Engine running, pour some in the carb and white smoke will come out any exhaust leaks. Look in the Marvel Mystery Oil thread from recent and the info is in there.
Gsub
Belgium
Gert
Suburban C10
350runner
tx
Ceasar
Ah now it makes sense that it goes away after being warmed up
350runner
tx
Ceasar
Skweegle89
Oklahoma
While we're on the subject, and I'm not trying to get you to change the oil you use, but oryllies has a deal right now where you can buy 5 quarts of casterol gtx high mileage and their house brand filter (allegedly made by Wix) for $25
Gsub
Belgium
Gert
Suburban C10
Thx to say it, but i life in europe, it will cost me 100 dollar to send it over here :))
what kind of oil should i use, because i'm only using the 15w30 for a month and now having this problem, i has to be the wrong oil ???
you guys think its a lifter issue ??
Skweegle89
Oklahoma
There are 100 different opinions. I use 10w 40 and have always put casterol in everything I own. 10 different people will give you 10 different answers.
zippo854
