time for new tires
mistaake
SF Bay Area, California
Michael
Crown Vic
235/85R16 I think is the correct size.
I have never bought tires before, so I'm hoping for some input. Here are my criteria for the new tires, sort of in order of importance.
-price
-fuel economy
-quality construction and design and good grip
-ride quality and quiet road noise
-looks
Its a 2wd truck so I don't think I'll be doing any any off roaring. Thank you in advance for any suggestions :)
CSFJ
Have you checked out tirerack.com yet? It may give you some good ideas on what to look for. they have a section for each tire where they post customer reviews. Find the ones with similar vehicles and you'll get a good idea of what to expect from the different tires. We used to use it all the time at the dealership when a customer wanted a new set of tires.
mistaake
Michael
Crown Vic
So, if I order them online, then will any tire place install them?
Eidt: so I looked at Costco the cheapest tires they have are bfgoodrich at ko for $165, bridgestone duravis r500 HD for $160, and bridgestone dueler at revo 2 eco for $165.
Tire rack has some cheap kumhos but then there is $60 shipping, and I still have to get them installed. If I go ahead with Costco its only $15 per tire for installation and everything else.
Also I will check the most reputable local place Cains tire. They have a big banner "we beat Costco"
Only problem with Costco it means driving 15+ year old, bald, bulging tires on the highway to get there.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I just did some tire shopping for my Silverado. I ended up buying them at Costco- but they had to order them in. They were cheaper than discount tire direct or even tire rack by the time I added shipping then having a shop mount and balance them. The tire shops here are getting quite rude also when you bring in tires not bought from them. They end up charging way more. (At least $80 if not more).
I like having a tire waranty with costco also. I ended up having to use their road hazard waranty last year on my car. They replaced the tire and charged me $25. Not going to be able to do that with mail order tires.
mistaake
Michael
Crown Vic
Does Costco perform an alignment though? I think the local tire shop includes that. Isn't that something that should be done every time you get new tires, though?
77 K20
Montana
K20 5" lift
HT383 fuel injected
I'm not aware of any that do alignments. If your local tire shop will do that with a set of tires that will save you around $70 or so.
I usually get an alignment when I get a new set of tires. My K20 will hold an alignment way better than my Silverado. That solid axle just doesn't get knocked around as easily. EDIT: I just noticed your truck is 2wd. Don't know how well those hold alignments...
Moderator
2wd trucks hold an alignment just fine. My C10 was last aligned 8.5 years ago and it still tracks perfect and the tires have still been wearing perfect.
I wouldn't buy tires somewhere just because they give a free alignment. Often that is just something they do to get you in the door so they can sell you more parts. Which is fine, but a shady shop will try selling you parts you don't need.
mistaake
Michael
Crown Vic
My C20 spent the last 15 years sitting in a field. Could it have "lost" the alignment?
77 K20
Montana
K20 5" lift
HT383 fuel injected
The alignment should be fine- however I'd check out all other rubber on the truck real well. Brake lines, rubber suspension bushings, belts, hoses, things like that. Rodents could have munched on them, or they could have started to dry rot.
GRat
