Tilt vs. Non Tilt Ignition Switch Wiring
Ronno6
South Mississippi
Ron
I am installing a tilt column on my '84 C10.
I have read that the ignition switch is reversed between the 2 columns as the actuator rods move in opposite directions.
Does this mean that the non-tilt column harness plug just twists to connect,
or does the harness plug need to have the pins relocated, or, do I need a new harness plug?
Thanks.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The wiring is the same, you just need to move things around so they will plug in.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
GM ignition switch pinout wiring is the same tilt/non tilt. No changes needed.
Ronno6
South Mississippi
Ron
OK.
I twisted the plugs around and reconnected.
Cranks and runs just fine!
Thanks, y'all.....
But....I have found that the steering itself is a bit off....in order to go right, I have to make 3 lefts......
lawsonR98
