Rustisbest
- Jul 20, 2021
- Tennessee
- Matt
- C10
- 6.17775926 liters, 3L80, 228.6mm axle
Anyone in readerland mess with their governor to get the light throttle shift points later? Mine is shifting at 8 mph and around 18 into high gear.
I've tried adjusting the modulator and grinding the outer weights but it hasn't helped as much as I wanted. Will grinding the inner weights and going to lighter springs affect the light throttle shift points?
Had the same issue but worse with the TH350 before I swapped in the 400.
FTI 9.5" 3000 converter
3.89 gears
Looking for what somebody has actually done with a similar setup, car or truck, not Googled answers.
Thanks
3.89 gears
Thanks
