technique for emblem replacement on 85?
turbobuick1
Michigan
Tad
4.8L
Hi guys! For an 85 C10, I’m getting ready to replace the front fender emblems. They’re in poor shape and I have no interest in saving them.
I’m trying to avoid removing the fenders, and it doesn’t look like you can get to the backside, but possibly if the inner fenders are removed.
Anyway, I’m wondering if anyone has had luck breaking off the old emblem, and using barrel nut inserts when installing the new emblems?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Mine look like they’re riveted in but I may be mistaken or it might not be the original fastener.
If riveted, drill them out and re-rivet.
Craig 85
Nashville, TN
454/TH-400/NP205
Here's a picture from eBay. You can see there are nuts on the back side. Taking out the inner wells and maybe removing the bottom fender bolts will give you full access. IIRC the 73-80 used barrel nuts for the emblems. You would probably have to drill out the holes in the fenders to make them work as I believe the pins for 81-87 emblems are pretty snug fitting due to the fact they use nuts to retain them. Any slop would have put the emblem at an angle.
turbobuick1
Michigan
Tad
4.8L
Thank you Craig, that’s exactly the info I’m looking for! I had read about the barrel nuts on another forum, but realize that must apply only to 70s square bodies. I’ll use your info tonight to tackle the project after work.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
My old c10 i removed the emblems 30 years ago and to the best of my recollection with a hammer and screwdriver. expect some minor body damage. shouldn't be an issue if you are putting on new emblems. i think you can get to the front nuts with an extension and a swively or a wrench if you remove the inner fenders.the rear nuts you have to pull the front end or brake them. Another option would be use a cut off wheel or drill and grind through the face of the emblem where the stud is and push the stud and nut through the back.take you time so you dont burn the paint and you should have no body damage.. On my current truck i removed them while the fenders were off the truck and used barrel nuts to replace them after painting ( 3/16 stud x 7/32 hole ) . found them on ebay from a company called yearonemuclecarproducts $9.90 the look and work fine but don't pull down 100% you can slide a business card behind them. over all im happy with them. mine is a 77 so the size may be different on your 85
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
73-80 used nuts to hold them on i dont think the factory ever used barrel nuts on any of them
turbobuick1
Michigan
Tad
4.8L
This is also very helpful, thank you. I’m also considering the grinding/drilling through carefully, push through the pins, and maybe use 3m double sided emblem tape? Appreciate the responses guys.
Craig 85
Nashville, TN
454/TH-400/NP205
3M tape probably won't work unless you don't use the black liners behind the emblem. They protect the body from the emblem and extend past it about an 1/8th of an inch.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Or you could use the double sided tape on the black liner to the fender and then on the emblem to the black liner. The lip on the liner might hide the thickness of the adhesive. Or maybe glue the the emblem to the liner and use the foam tape to attach the now one piece emblem/liner to the fender.
Shorty81
Baby Boomer
North West ohio
Darren
I used 3M double sided tape and it worked well.
turbobuick1
Michigan
Tad
4.8L
I ended up using double sided 3m tape like shorty81.....worked perfectly! I’ve been putting a ton of miles and driving 70-75 down the highway, and went through an automatic car wash and the emblems are there to stay. I bought a set of reproduction emblems on eBay (gorgeous btw) and chose to not use the thin black spacer on the backside. Here are some pics. One pic is how I laid the tape on the backside of the emblem. I used an angle grinder and carefully ground through the old emblems above the pins, until I could break the emblem off the fender.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Yeah I admit that's more sane than JB Weld..(yes I did and it worked)
reese68
