TBI stumbles at idel
ggenovez
DFW
George
R1500 Suburban vin k
Hi all,
I have a 90 burb 350 R5100 2wd TBI and I've noticed it wants to stall in gear while I'm waiting for a red light.
Idles along then then rpm's drop, stumbles, comes back up, rinse and repeat.
I've recently had a bad CTS and TPS so they are new.
Any thoughts?
4WDKC
Southern Florida
Kacy
check fuel pressure, get a scanner or make your own cable .
If you want to try parts, the IACV might be your guy, but a scan of your serial data would be revelatory in your situation. There’s a stickied thread in the TBI section on how to make your own cable. I’d also like to know if there were any serious vacuum leaks going on.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
ggenovez
DFW
George
Thanks.
Fuel pump is new. Tested recently at 13 PSI.
When you say build a cable is that something beyond jumping pins 1 & 2? It's a ALDL conneciton
Jppr26
Deer island
V20 custom deluxe
Check your idle air controller
gmbellew
Kansas city
glen
suburban 1500
i had similar symptoms and it turned out to be the early signs of a failing intake manifold gasket. it would drive fine, but sitting at a stoplight it would do as you described.
Mousta5
