Mattchu60
- Jul 25, 2012
- Iowa
- Matt
- k10
This winter I am going to replace my motor with a GM TBI Crate motor as its worn out.
I would like to do replace the intake with the Edelbrock TBI performer. I am leaning toward using the stock exhaust manifolds over going to headers as well. Also I would like to put in a different camshaft for just a little more power over stock.
Looking at a Comp Cam, there are two which seem pretty mild:
COMP Cams#249-12-304-4
Computer Controlled Hydraulic Flat Tappet Camshaft
RPM Range: 700-4700
Lift: .406"/.406"
Advertised Duration: 252°/252°
Lobe Separation Angle: 111°
COMP Cams#249-12-388-4
RPM Range: 1000-5000
Lift: .425"/.440"
Advertised Duration: 252°/260°
Lobe Separation Angle: 112°
Not looking for crazy power, just a little more than stock.
Here is my big question - if I just did one of the above cams and the TBI intake, would I need a ECM program? Or would I be ok with running a stock computer?
RPM Range: 700-4700
Lift: .406"/.406"
Lift: .425"/.440"
