Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
So I'm preparing to install my sending units and realize something: The tanks are mounted too far back (5" maybe?). Basically one set of mounting holes off. The rear just needs moved up one set of holes - the front can only mount one place but the tank has to go forward a few inches. No biggie.
No problem except the front part of the tanks where it needs to be strapped is a whole lot larger than where it was. No way will it fit - at least 2" shorter. Rear goes in just fine, but the front will not. I used a dead blow and flattened the seams - like I did initially - not a chance. Used a floor jack - helped some but still not close. I cannot be the only one who has ever had this - whats the secret? Longer custom straps? Dent the top of the tank down? Everything is Spectra brand. 87 tanks....and original 85 straps.
If there were mounting holes forward of the front straps, it'd be perfect. Any ideas?
Rear strap - perfect.
Front strap - 2 in or so short. This is as close as its getting (top hole even - add 2in to get it to the bottom hole like it was).
Area where it is vs where it needs to go.....can see the hump.
