Suspension Lift ID Help
zking504
florida
Picked up an 86 K10 stepside 700r4-np208 sitting on bald 38.5 boggers with a 14bff swap. Looking into upgrading a few things but wanted to try to figure out what type (manufacturer) Suspension lift it has already. I was told it had 12" of lift (8" suspension w/ 4" body lift), but im kinda skeptical about the 8" suspesion part. From what I can tell it has 2" lift blocks in the rear and aftermarket springs mounted in the stock positions i think. Any help ID'ing the suspension would be appreciated. This is a hunting/mud truck only and will not see any pavement use. Planning on upgrading the front to a dana 60 and fit some 18.4x16.1 american farmers under there in the near future. Def. needs more lift to fit the tractor tires and more mods but not sure what im working with (suspension) to start.
How she's sitting now
Front leaf spring on the GM10bolt
Front leaf rear shackle
Rear Leaf on the 14b
Rear leaf shackle (Stock?)
Rear lift blocks/pinion angle pic. Pretty sure its a first design 14bolt.
Thanks!
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Be a fun toy when you get the farmers on it. What part of Florida are you in?
Swims350
Logan WV
none
why does everyone say 4 inch body lift? unless it's an illegal home built body lift it's 3 inches only or 2 that's it.
Now it definately looks to have one, I'd say 3 inch, I also see what looks like 2 inch rear blocks under the rear springs, are the fenders front or rear trimmed? they look like it. I'm thinking it's a 6 inch kit then 3 inch body lift but I could be wrong.
smurph20
Brad
Hey Swims it still has the factory lip on the front cant really see the rears.
Swims350
Logan WV
none
actually the rear most rear, looks to be stock too.
zking504
florida
Its definitely a homemade body lift. lol. Most of the tubes measure 4" with exception to the fronts which are 3". There's a little trimming on the front lip of the front fender but it doesn't look like the rear fenders have been touched.
Smurph,
Thanks I hope so. Im in Jupiter just north of west palm area.
smurph20
Brad
Cool i used to live in Winter Garden just west of Orlando. On your lift is there any numbers or marks that could help identify it as in some kind of part number or something.
Knightewulf
