idahovette
- Aug 7, 2016
- Weiser Idaho
- Perry
- K20-K10
On C10s you gotta put shims on the front bolt or take shims out of the rear bolt to increase Caster. You need the angle of the upper ball joint rearward from the lower (+Caster)Adding shims to either will increase Camber, but you gotta know how much does what. Experience will teach you how many shims and what thickness and where to put them.........Then set the toe....(@bucket )...lol
