Superlift leaf spring direction
hendo78
California
Im getting ready to install a 8" superlift on my k10. The rear leaf springs bushing eyes wrap around the bushings in different directions. (One side wraps over the bushing and the other end wraps under the bushing). Which side goes towards the front of the vehicle? There are no shims pre-installed to help identify the direction.
xm20k
Girard, Ohio
The one that goes under is the fixed end the over is the shackle end, so it doesn't hit the shackle when flexed a lot if I remember correctly. Spring ends are typically the same on these trucks with the exception of the longer spring packs that have a longer rear section from the centering pin.
Skippy
