Superlift springs
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
I have a 86 k20 with 8" superlift springs on it, as well as a duramax engine installed. I've recently noticed that the driverside is saging about a 1-1½ from fender well to tire if I remember correctly. What do think is causing it D-side leaf failing?
I've measured everywhere I can think of on each side of frame, leaf spring bolts, frame to top of axle and all measurements are equal.
nvrenuf
Mobile, Al.
Gas in the pass side tank making it lean?
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
Its the d-side front that is sagging down.
Moderator
How old are the springs? Seen any air time?
^That's a serious question, not a joking one.
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
Brand new springs
Only been driven on 5 months other wise been bolted onto rolling chassis while being built for 4 yrs
Moderator
Brand new springs
Kind of annoying, but you can swap sides and see if it tranfers.
duncan_schawalder
