DoubleDingo
- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Carburetor guru's I need some input about this issue I am having. I haven't drove the truck much after I got the engine back in it, so that may be part of the problem. I do add at least 10 gallons of 91 octane each time I start driving it again, and sometimes just fill it up and cuss the oil company that steals my $80-$90.
Okay the problem I am having. You can hear a mild miss at idle. Timing is set to 10* btdc, and the vacuum advance is per the factory set up, so it is probably ported. It has all the factory emissions stuff installed. When I first fired up the truck after stabbing the engine, the mixture screws didn't cause the idle to change at all so I couldn't adjust the A/F mixture. I ran some Motor Purr in the tank and a couple days later the mixture screws were doing their job again, but still not right like they were before. The truck seems to run well down the road, and for the most part it accelerates okay, but I can tell it's not running at peak performance. I added a mild cam while the engine was out, so that and the engine being resealed is the only difference. This stumble issue didn't happen before the cam swap and engine reseal. When I go to take off from a dead stop or even rolling start with a lot of throttle, it takes off fairly decently even with the mild miss, but as soon as it shifts into 2nd gear it literally falls on its face like it died, but then it picks right back up again and takes off.
What do you guys think it is? I was wondering if it may be the choke flapper closing and/or opening because the guts of the choke are not all there. Or maybe something internally in the carb? Or possibly a vacuum leak, or maybe one or more of the check valves are no good. Before I put it back in I sprayed carb cleaner in all the ports but not with the nozzle spraying full force. Also sprayed carb cleaner over the entire outside, inside, topside and underside of the carb except I didn't take it apart to spray in the bowl area. Something isn't right and it is really bothering me.
