Stockvs Ram horn manifolds
77 K20
Montana
K20 5" lift
HT383 fuel injected
I had the exhaust shop install some center dump 2.5" ram horns on my truck years ago when they were redoing the whole exhaust system. Didn't quite fit on the driver's side due to clearance issues with the motor mount. The modified the mount a bit to make it work though. This was 12 years ago and haven't had any problems with them since.
EDIT: The manifolds did have some odd bracket that was built in for power steering? The bracket stuck off the front of the manifold. Exhaust shop cut the brackets off and ground them down.
full
full
full
Moderator
full
full
full
That bracket was a generator mount.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The older ramhorns had that mount.
I have ORD motor mounts which are a considerably smaller footprint than stock. I won't be so hesitant to move forward with center dumps now lol
longbeach
Maine
Wayne
Those look great. I was under the truck yesterday doing some measuring. I was thinking of going with a rear facing dump on the drivers side and a straight down dump on the passenger side.??
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Kinda unrelated but I feel like sharing my new (used) 2.5” center dump Corvette manifolds
longbeach
Maine
Wayne
77 K20, Do you have a couple of pics of the down pipes from under the truck? I'm trying to figure out about how long that pipe needs to be before 90 degree bend aft. Thanks
77 K20
Montana
K20 5" lift
HT383 fuel injected
I'm a long ways away from my truck right now but I have these existing pictures that kinda show how far the pipes hang down and their routing.
full
full
full
77 K20
Montana
K20 5" lift
HT383 fuel injected
Found one right after the exhaust was installed. Exhaust pipe isn't rusted yet. :rolleyes: It was backwhen I had the full size stock starter even.
full
With the engine replacement I went to a GM performance starter. Much smaller and cranks the engine faster with less current.
full
84GMCSierra
Supporting Member Air Force
Central Arizona
C2500
I have a set of factory ram horns off of a mid 70's GMC C8000 with a 350 that I am going to have installed on my 350. I need to go to them as my dipstick went from the right side of the engine to the left side, and with the stock manifold going "over" the spark plugs, I can't put in a dipstick. I'm also going to see about a set of spark plug wire retainers. First pic is the ram horns I have, and the 2nd pic is the stock manifold from 84
blue10
