Stock proportioning valve w/ disc brake conversion
tiredtiretodd
NORCAL
K 25
Does anyone know if you have to depress the pin on the proportioning valve to bleed the rear brakes? Also how do you go about properly bleeding them?
marks86
Latham, NY
Mark
12v Cummins
I just re bled them normally, Don't think I even had to do the fronts
I didn't do anything with the proportioning valve at first I did bleed the brakes
tiredtiretodd
NORCAL
K 25
Thanks Mark, I'm gonna bleed them and see what happens.
marks86
Latham, NY
Mark
12v Cummins
no problem let us know how it worked out
cbrodine
NW Ohio
Collin
C25
did you convert from a disc/drum setup to a disc/disc setup? If so, you shouldn't being using the then stock prop valve...you'll need a disc/disc prop valve for proper use.:)
marks86
Latham, NY
Mark
12v Cummins
whats the difference?
cbrodine
NW Ohio
Collin
C25
Pressure....disc brakes operate at different pressure then drum brakes. That's why there are proportioning valve's for drum/drum, disc/drum and disc/disc. I found a GM style disc/disc prop valve for $35 on eBay. I did a rear disc brake conversion on my 73 GMC C 25 w/a 14 bolt FF. Get a disc/disc valve, it's cheap and will bolt right in place of the original. :)
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I added an adjustable prop valve to mine and it seemed unnecessary. It all depends on your setup, with my 1-tons and huge tires the increased clamping force on the back is welcomed, much less nose-dive on braking than before.
Posted MOBILE!
tiredtiretodd
NORCAL
K 25
i ended up not doing anything and they work fine, just needed to drive it and pump the brakes up. As for the prop valve, i don't think it was ever changed, it looks like the original and the rear discs are working
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Your rear brakes won't wear at the same rate as the front brakes without the right proportioning valve, which isn't that big of a deal but if I did a disc swap in the rear I would do it right to get the max life and performance from the uprgade, but that's just me!
tiredtiretodd
NORCAL
K 25
I was fortunate to buy the truck with the discs already installed on the rear. Now I will most likely install a disc/disc prop valve that is adjustable. The problem I'm running into now is that I don't have a ebrake.:whymewhyme:
Dennis Blom
