Steering column?
Steve-o81
Festus, MO
Steve
Hi, dumb question but I was going to buy a factory style steering column unit to replace my original. They say they take old cores, but mine is pretty parted on the outside but insides are 110,000 miles and nothing wrong with them. Would they still take it? If so I think I’d get a discount but I forgot. It’s off my 1981 Silverado half ton.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I think you'd have to ask them. Everybody is different.
Raider L
Shreveport, LA
William
@Steve-o81,
What's wrong with the one that's in your truck now? Any pics? What is it you want to do with the old one, the new one?
Steve-o81
Festus, MO
Steve
@Steve-o81,
I just wanted to replace everything I could mechanically is all
Raider L
Shreveport, LA
William
@Steve-o81,
What are you working on? Tilt or standard column? Automatic or floor shift? Three on the tree? Three speed or four speed? What year? Give us some idea and the flood gates will open!
Steve-o81
Festus, MO
Steve
Tilt, auto trans th350, 1981 Silverado 1/2 ton
Raider L
Shreveport, LA
William
@Steve-o81,
You don't like the tilt? Something is wrong with it? What? Want to keep the tilt column but shift on the floor? What? Want a standard column with shift on the floor? What? Have shift on the column, but has problems? What? Can't shift it anymore, something broke? Or like one guy was having a problem after putting in a standard column, he brought the tilt ignition switch over to the standard column and found the ignition switch pattern was reversed from the ignition pattern he had when it was a tilt column. The pattern IS reversed from a standard to a tilt. Or what Steve? Need lots more info, pics!
sallyjeank10
