Side and Spider Gears
cobra20
Portland, Oregon
Hans
V1500 Suburban, K5 Blazer
5.7L
I need a set of side and spider gears for a 30 spline 8.5 inch 10 bolt
You have a local driveline parts shop? There should be a spider gear kit available new, from what I remember, it's not expensive.
cobra20
Portland, Oregon
Hans
5.7L
autozone wants 200 for the kit
MrMarty51
Eastern Montana
Martin
Check that the hole, where the spider gears main pin goes through the ring~gear carrier, is`nt all wallowed out first.
If it is, You will also need a ring~gear carrier and a pin too too.
cobra20
Portland, Oregon
Hans
5.7L
nope not wallowed out at all just took out a couple of gears suprisingly
Sucks buddy but at least you caught it before any major damage. Any luck finding replacements?
cobra20
Portland, Oregon
Hans
5.7L
found a 28 spline posi not sure if the 30 spline gears will fit inside it
No junkyards near you? I had to do this one time with a dodge pickup I had. Just swapped the spiders from a donor unit and it was fine.
MadOgre
NA
NA
NA
NA
NA
That does you no good unless your getting the matching axles for it. What are they 5 lugs ?
I would personally just replace the whole thing with a new Detroit true trac.
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Rockauto like 100 shipped. Just got some 28spline ones myself
cobra20
Portland, Oregon
Hans
5.7L
It is from a 6 lug truck like my suburban
