Show me your “fangs”
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I’d like to get some detailed pictures of how people have cut the front of the front fender wheel opening to clear 35” or larger tires. I plan on getting a set of aftermarket fenders to cut so the truck can be reverted to stock original sheet metal if wanted.
Thanks in advance.
Craig 85
Nashville, TN
454/TH-400/NP205
I've always trimmed near where the trim screw is (red circle) and run back at a diagonal to where the inner fender intersects the bottom of the fender. I added the yellow line for the cut on the front of the fender since I couldn't find a better picture. I follow the front line of the fender down and cut the corner off. I know you don't have trim, but if someone here does, I then move the last screw to retain the bottom of the trim.
If you want to get crazy there's always photo #2, but you can't go back to stock. I used these on my K5 since it let me cut the rust out of the bottom of the rear fenders.
DawgmanDew
