rusty floor, rocker panel, kick panel repair V10 1987
roadwolf
France
Rodolphe
silverado 10
Here is some pictures of the works done on my 1987 5.0 long bed.
The rocker panel, side part of the floor and the kick panel was gone, i bought replacing parts and cut the rusty parts then welded (not me a friend) the new parts.
the floor, the kick panel, and the front inside panel are done.
next to do, the rear cab corner and the outside rocker panel
74 Shortbed
It's coming along real good..
DanMcG
Central NY
k10 k10
He's doing some nice work, is the floor pan butt welded? or lapped?
roadwolf
France
Rodolphe
silverado 10
It is butt welded, once the weld are grinded, you almost can't see the joint.
roadwolf
France
Rodolphe
silverado 10
here is the next step
next time the cab corner
74 Shortbed
Nice work..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Great job!
cooperhw
Mesa AZ
Wayne
C-10, K-20, C-20
5.7L
doing a good job.
roadwolf
France
Rodolphe
silverado 10
here is the next step th cab corners and the cab bottom rear panel
on the right rear before
and my friend spot welding the patch
the left side with the door on to check missalignment
I have to rework the bottom line of the left rocker panel which is not very straight, some hammer job should reshape it the right way.
That was all for a saturday job.
roadwolf
France
Rodolphe
silverado 10
here is some news
the driver side rear cab panel is patched
now the passenger side
as the side of ther corner har already been replaced and most of the rocker panel is in good shapee, i only did the rear part which is easier to put in location.
the part welded with a few spot
now fully welded
roadwolf
France
Rodolphe
silverado 10
The whole patched parts primed with zinc to avoid rust to come back
Now the passenger side rocker panel
At fisrt it doesn't seem to be to much damaged but
The bottom of tha A pilar has vanished so more cutting is needed
inside the cab
roadwolf
France
Rodolphe
silverado 10
Cutting to floor until finding not rusted zone
Welding a part cutted from a new repair floor
Now rebuilding the inner rocker pannel
i did different tries to join the floor and the inner rocker panel, so the part is modified in the next pictures.
Joinning the floor and the rocker by hammering and then welding, and then put back a new bottom A pilar part cutted to fit my cut lines.
Next week i hope to put back the external rocker panel, and the metal part of the body work will be done.
imyourhuckberry
