Running speaker wire to the rear single cab speakers
Edhard_Stark
Connecticut
Ed
Hello ya'll,
I'll be doing a cab swap soon, and when I put the new cab on I'll be installing sound deadener and rubber matting. While I'm there I'd like to run new speaker wire to the speakers(that I'll be installing later). My question is, what kind of wiring should I use? I have no problem spending money on good wire, I want a solid foundation for a 4 speaker setup I'll be using. I'll be using dual speakers I got brand new for $10 a pair, but I'll be upgrading down the road to something much better because I only want 4 speakers and no sub(for cost, ease of install, etc.). My HU is an 2010ish Kenwood exceleron but I love it and I don't plan on replacing it unless it breaks.
firebane
Calgary, AB
Curtis
18g or 20g will be plenty.
Edhard_Stark
Connecticut
Ed
Should I need any special speaker wire to help with sound quality, or I should just use basic insulated wire?
firebane
Calgary, AB
Curtis
Just basic insulated wire will work fine. A good crimp and connectors will make the biggest difference.
Edhard_Stark
Connecticut
Ed
Yup I have plenty of good wire and crimp connectors with heat shrink. Thanks!
Konas new ride
Alberta
Gerald
If your going to the hassle of running new wire.. installing a good set up.. don't use normal wire for your speakers, Use speaker wire. Solder and heat shrink the connections also.. 50 feet of decent speaker wire cost me 12 bucks.
yeol1
East TN
Joe
Good wire makes all the difference. I personally always use 12ga but I also normally run an amp for everything. If your just using you head unit 16ga will be fine, but if it was me I would run good quality 12ga and not worry about it later.
Edhard_Stark
Connecticut
Ed
You guys have a point, and the 12ga is a good idea. I can be very indecisive about mods and I like the idea of wiring an amp in for the speakers. I'm not a sub guy, so wiring an amp might be a good move if I'll only have 4 speakers.
yeol1
East TN
Joe
Yeah I know with mine I wish I put an amp in. At idle the speakers are loud enough but when driving especially with the windows down I have to turn my head unit all the way up to hear my music. Also already having the amp wired in gives you flexibility. I know JL makes a 5 channel amp incase you want a sub later. They also make a 6.5in sub that sounds amazing. Just enough added low end to make your music sound better but not enought to rattle you or be annoying.
EDNOMAD
