bad neighbor
- Jun 29, 2017
- Flint Mi
- Randy
- Suburban C20
Hi all
My truck has been running great for a few months now after locating a rough idle problem and repairing it. Turned out to be a cracked cruse control hose that came off the intake manifold. Had rough idle and raised the rpm. Repaired the hose, idle smoothed out and rpm dropped to normal. Cool.
Now I have a new rough idle, not as bad as last time, and the rpm's have dropped. What the heck?
First thoughts was that I had another bad vacuum hose possibly coming off the top of the carb. Found nothing that stood out as the problem.
So the EGR came to mind, but this is the first engine I have ever had with an EGR so not sure what to expect if they malfunction.
I have the shop manual found on this site, but it is missing the diagnosis sections.
Also checked the PCV valve and appears to be working properly.
The crazy thing about this is overall performance seems to be better. IE I feel a little more power ???
C20 85 Suburban 454 4BBL carb
Thanks for your input
