Rotted out EGR diaphram frame
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
Actually getting ready to do the same. High rise (stock) cast iron 4.3 Qjet intake. Had to pull the a/c compressor and mounts, air pump tubing and fitting, and a couple dozen vacuum lines/wires, to remove a valve cover. First time off in 40 years.
Jeg’s stand alone hei distributor, no esc connections.
Earlier Qjet w/o all the vacuum actuated or esc tie in “fiddly bits”.
Vacuum “tower” on the front of the intake fell apart. Wonder if I can replumb that for the power brakes…
Truck was special ordered with 4.3, Th400 and open 2.73 rear gears. So much easier than fighting a 700r4 with 3.42s like my 4wd has.
Keep the Qjet 4.3, pop the hood at cruise night, and stay nearby… People’s reactions to a micro engine in a Square are hilarious…
Original
