Roller Rocker Arm Situation
Ronno6
South Mississippi
Ron
Tall valve covers wouldn't solve your valve cover issue? I know it does nothing for your side to side issue but, at least rockers wouldn't hit your covers. They're pretty cheap. I've got a set on mine.
Yup I have tall valve covers.
The issue is not how tall the arms/polylocks are;
the issue is the very edge at the pushrod end is contacting the vertical wall of the valve cover.
Basically stated, the end of the rocker arms may scrape the inside wall of the valve cover as they move up and down.......
Ronno6
South Mississippi
Ron
got any pics of way the roller looks like on the top of the valve stem. that’s what matters.
Here ya go....I am not the best photog in the world tho.
kenn
detroit
ken
c10, k10
mine hit as well, switched to comp cams roller tips much smaller on the side by intake, roller seemed little wider than the scorpion rockers
COMP Cams Magnum Steel Roller Tip Rocker Arms 1412-16
Ronno6
South Mississippi
Ron
Thanks, Kenn.
I was hoping to stay with a full roller rocker.
Got a great deal on these:
PRW #0235010
They are self aligning, but I'll use my adjustable guide plates as well.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Ok gotcha. Musta miss that part. Lol
Moderator
Are they centerbolt covers? Perimeter bolt covers should have more clearance.
Ronno6
South Mississippi
Ron
Looks like the Scorpions are going back.
Gonna see how the PRW's and the adjustable guide plates work out..........
Moderator
With the self-aligning rockers, ditch the guideplates altogether. Besides being redundant, the angle those heads put on the rockers can cause binding when using the plates.
Ronno6
South Mississippi
Ron
Gonna hafta put washers under my studs??
Moderator
No, rocker adjustment process will be the same. The overall height of the studs will be lower, that's all.
Ronno6
South Mississippi
Ron
I'm fearing that the extra length of the stud will either bottom out on the blind holes or protrude into the intake runners on the others..........
workinman789
