Replace spark plugs (1982 C10 Inline 6, 4.1L)
Brownie82C10
Winter Haven, Fla.
Joe
Chevy C10
4.1L Inline 6
My regular truck fix-it place wants way too much money to replace the spark plugs in my '82 Chevy, so I thought I would do it myself. The back four plugs are easy to get to, but the front two are not. Can anyone provide the how-to steps for plug replacement or provide a link to a video that shows the best way to do this? Many thanks.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
DBarre
Rockport, Texas
Dustin
250c.i./4.1L
If you have a/c on the truck it is difficult to get the front spark plug. You'll probably have to loosen or remove the a/c compressor bracket from the engine. Then with the correct spark plug socket and about a 6" extension on a ratchet, you can get the plug out of there. The number 2 plug should be easy with the 6" extension. Hopefully whoever put those plugs in there didn't go crazy tightening them down.
Brownie82C10
Winter Haven, Fla.
Joe
Chevy C10
4.1L Inline 6
Thanks, DBarre. Yep, I have A/C on this one. I'm not sure I feel confident messing around with that.
DBarre
Rockport, Texas
Dustin
250c.i./4.1L
Have you worked on cars before? These straight sixes are simple beasts once you get past the emissions stuff.
Try the hardest plug first without moving the a/c bracket. If you can't get it, the hoses have some flex in them and you don't need much room to get a socket in there. You can just loosen the bolts without taking them completely out. I think if you get in there, you'll figure it out.
Pictures are good if you need more specific help.
Brownie82C10
Winter Haven, Fla.
Joe
Chevy C10
4.1L Inline 6
I've done relatively simple repairs and upgrades on several vehicles through the years, but I wouldn't call myself a mechanic. I would call myself impatient and sorely lacking in time to take on projects like these. My usual fix-it place (a national chain) wants $100 for the labor to change the spark plugs and almost $70 for the plugs. I think both of those charges are outrageous. I bought the plugs I needed for less than $17.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
If you are unsure you can do it, find a friend, neighbor that can help you.
Brownie82C10
Winter Haven, Fla.
Joe
Chevy C10
4.1L Inline 6
I used to have a neighbor — a really good mechanic for the local school district — who worked on this truck and other older vehicles for me, but he's moved away. I don't have anyone else to call on.
Thanks for corresponding.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Spark plug sockets often have a hex shape on the drive side. Sometimes you can slip the socket on the plug, then use a regular open end wrench to turn the socket. This is helpful when a ratchet wont fit on the end of the socket due to clearance issues.
  • Like
Reactions: WFO
aaron06
