1982 c10 neutral safety switch
brisenob
Baldo
New here, just got an 82 c10 and working swapping out the steering column with a CPP one. Problem is it came with a neutral safety switch already mounted and it looks different than oem. I got 2 plugs going in. The yellow/purple seem to plug right in, but the blue/green dont. Seems to have different orientated ends. I plan to just add female ends and plug them in. Just curious which one goes where. Picture 1 is OEM switch, Picture 2 is what I got and Picture 3 are the 2 plugs with the yellow/purple plugged in. Any help will be greatly appreciated!
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
That switch looks wrong. If you look up the switch for a 1982 it looks like the top picture of your original one. The one on your column is for a much older GM vehicle.
Why not just replace it? They are less than $20
brisenob
Baldo
That was my first thought, but the tab on the switch that slides into the column is different. It won't fit. I tried swapping switches but won't work. Just my luck!
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
then you have an old column. Probably best to replace the connectors to match the column.
Chrispy
