86blazer32
- Feb 12, 2018
- California
- Michael
- Blazer
Hey guys currently in the middle of wiring up my Holley terminator kit with the 6 speed controller. Im trying to figure out where to wire for the neutral safety switch. Looking for guys who have done this before.
It is asking for a ground in park and neutral and an open circuit in gear. I was able to find a little diagram someone came up with for this exact thing but it appears my neutral safety does not match and only has 2 wires running to it. I imagine these are just for reverse lights. Others have stated these blazers didn’t have neutral safety switches because the column is supposedly suppose to inhibit you from turning the ignition with the truck in gear. I’ve tested mine and that is not the case so I really would prefer to get this thing wired up correctly.
Any body have any recommendation on what I could do? I can get the 5 wire neutral safety from a local auto store but am not sure if it will work since my blazer doesn’t have any of the other wires that run to it. I can run all the wires shown on the bottom portion of the diagram but I do not see how it can provide a switched ground without a ground wire running anywhere to it. Unless is ground through the body to the column but as far as I can tell the unit is all plastic.
