Removing Smog on a 81 305
Ohio
Gideon
5.0 305 4BBL
Hello!
I have a 1981 C20 with the 5.0 305 with a 4BBL carb. I have a new exhaust for it since the one on it rusted away. I got Headers to tips and want to put them on. I would like some pointers for removing the smog system. it seems overly complicated and I am new to all of this.
Where do I start?
Any help is appreciated.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
And you don't need anything which has a belt attached to it except for your power steering, water pump, crank, and alternator!:cheers:
RoryH19
Rory
R10 Silverado SWB
Hello!
Where do I start?
Yes it can be.
You probably have a smog pump, connecting tubes, evap can, egr valve, etc.
Are you going to remove/replace the cat?
Post a picture and we can point out what to remove.
Ohio
Gideon
5.0 305 4BBL
Thank you all for the responses. let me get a few pictures up.
Don't forget the AC unless it doesn't have AC.
It does have AC as far as I can tell
Ohio
Gideon
5.0 305 4BBL
Additional info so you don't have to ask.
Truck sat for a long time, no idea how long unfortunately.
I am aware of my Brake Booster leaking real bad. working on finding a new one.
I am new to this whole thing but this truck has a lot of sentimental value so I want to fix it up and make it real nice again.
Ohio
Gideon
5.0 305 4BBL
See also this
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
:superhack: and :grd:
Jk welcome to the site from Texas
Ohio
Gideon
5.0 305 4BBL
Thanks! From poking around I believe I am in the right spot.
I very badly edited some of my photos of what I think I need to remove but I have no idea on the 3rd photo what is going on there. Can't tell if they are going into the head or just the headers
Paladin
"Teufelshunde"
Yep, there's the AC, ditch that too, that's what wing windows are for! And that 305 will thank you too.:cheers:
Ohio
Gideon
5.0 305 4BBL
Guess I should attach those huh.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
The air injection system, EFE, and the TVS that controls it would have to go for me. The TCC lockup switch would have to stay. I’d keep the PCV and canister because they perform jobs that are worthwhile IMO. The EGR would be up to you, and I suppose the EGR TVS would have to stay anyway to keep lockup from happening till operating temp. I actually can’t speak to the value of having the distributor delay valve. I’m assuming it manipulates the spark curve to what they thought was more economical back then.
Ohio
Gideon
5.0 305 4BBL
man I know 3 of those things ha. so it starts up right away now as is. not sure how but it does.
So the seems to me that the plan is to eliminate a lot of things correct?
Things to Eliminate:
Smog
AC
air injection system(what does that do?)
EFE
TVS
Maybe EGR
Things to keep:
PCV
Canister
EGR TVS
I need to get a manual asap
Carb'ed Vortec 350
You're in the USA, which state only you know. Any smog stuff you remove, keep it. You may need it later. Don't toss it.
Malo83
