81 C-10 Steering Jerk on a right turn only
Jtobe81
las vegas
Justin
1981 Chevrolet
c-10
81 C-10 2wd. It has the original steering gear box. new tie rods, control arms, pitman arm etc. It has been aligned at a shop recently.
My problem is it has a sudden jerk in the steering but only when your making a gradual right turn. highway driving making a swooping right turn it will jerk slightly left then center jerk again. the steering wheel does not go left with the jerk.
Its weird hard to explain. I plan to replace the gear box with a new quick ratio one and upgrade the front end with QA1 suspension.
Any thoughts appreciated thank you.
Chevy 88
Canada
f7t6
GMC
Make sure your U-bolts are tight on the leaf springs. Axle axle might be wandering when you turn.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Check ball joints and wheel bearings. Have someone steer the wheel back and forth slightly while you watch steering components.
duncan_schawalder
