Rear window visor
78C10BigTen
pennsylvannia
C10 BIG TEN
Anyone know if there is a rear window visor out there to go over my slider to keep the rain out when open?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
I've been around pickups my whole life and never seen such thing. Not for squares or mini trucks or furds or anything. You could invent something new!
78C10BigTen
pennsylvannia
C10 BIG TEN
Ive seen them on gmt400s...
SDJunkMan
Black Hills of South Dakota
Jeff
Are you looking for something like this? I have one of these that fits a square.
78C10BigTen
pennsylvannia
C10 BIG TEN
No like the vent visor rain things ya put on the doors but for the slider. Although that would probly work too
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
It’d be fairly simple to make one from sheet metal that has a fin that sits up in the slider groove with legs that rotate down into the lower groove for a compression fit. I have a brake and shear for making custom flashing and other architectural metal. I could draw you up something if I’ve done a poor job explaining it.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Hmmm...... I'd be interested in seeing a photo of it.
Dutch Rutter
Independence, Or
Joshua
Moderator
They don't do a very good job of keeping the rain out since the glass slides sideways. It just comes in right below the visor.
I remember seeing them on a lot of trucks in the late 90's and early 00's. But not since then.
Rob Goblin
Fayetteville, Arkansas
Rob
I don't know what I think about the one's Dutch posted about, maybe something like junkman posted. I'd like to see both on a squarebody though to know for sure.
Swims350
Logan WV
none
Those fiberglass ones that bolt on the bed or cab won't work, I mean they fit but rain will come in. The bed mounted as posted above sits behind the cab so rain comes right down, sitting still anyways driving it may stay out alot rain wise.
The other style as I had for my s10 that bolts on the cab well it comes up over the roof but has an air slot between it and the cab so basically air flows right over top of the cab between it and the fiberglass thing.
again sitting still would work some, driving would be better. The cab mounted style would actually work decent for rain in the slider sitting still.
I know the tape on type you speak of lik eones for sunroofs and windows. I too have not sen those in years.
souixchef2
