Rear Brakes Locking Up
bookit
Wyoming
Let’s think simple for a minute check the “E” brake / parking brake to make sure they are fully releasing the lever should release nearly to the rear shoe it only takes a little bit of tension on that cable to make a rear wheel lock up also make sure the rear brake shoes are the correct size and installed correctly
Knuck55
Chesapeake Va
Dave
1988 and another 1988
Suburban V10 G20
Was not going to sift 8 pages but Make SURE the master cyl has been bench bled correctly. Seen that problem more than once. Sorry if this has been mentioned already.
59840Surfer
Montana
Joe
Never push a brake pedal to the floor.
If the master is contaminated - it can pack crap in the forward piston seal and ruin it.
Always assume the master is contaminated and put a 2x4 or 4x4 under the pedal to keep your "helper" from jamming it all the way down.
Good help is hard to find and bad help makes you buy a lot of extra parts.
In all my years as a Brake/Lamp/Smog Inspector for the state of California, I have never seen GM use cross-fed brakes; that is if one fails the other two will take up the load, diagonally.
Dual masters have always had a front-rear split in that once the proportioning valve shuttles to the leaking side, the brakes that are applied are the survivors ---> front or rear.
Yes --- there were systems that shut off any flow to the ruptured system (front or rear) because the reservoir only had a small dam to keep the front and rear fluid kinda-sortta-almost segregated.
Has anyone told the OP to physically inspect the rear brakes for 90wt or brake fluid contamination or reversed primary/secondary shoes?
Brakes that grab or chatter or make noise, do it for a simple reason --- stop looking for zebras when you hear hoofbeats. Dem's only horses!
O.P. had his brake lines reversed at the master. So bias was totally wrong.
Shak379
