ram horn manifolds
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
can i use these on my 75 c30 i already got dual exhaust but my factory passenger side manifold is cracked and leaking pretty good and they other isn't any better.
and how well do these flow over the ones i have on my truck.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Rams horns flow very good, but they exit under the middle cylinders. I dont know if the motor mounts would be in the way, and you would have to get your primaries extended to reach.
I'd prefer to rock a set of ram horns over headers. NO, they aren't as good as headers but you can avoid alot of the issues that come with headers, like replacing gaskets and collector gaskets, keep your exhaust quiet if you like it that way, and get about as close to header performance as you're gonna get using ram horns. As Jim said, they drop in the middle, and 2 different ones too, one set will drop straight down, one set will drop down then angle toward the rear. Those are probably the ones you'd need, but you have room use what you can get. In short, if you are modding your exhaust, rock a set, you'll like them.
Jleopard77
