Engine woes
Ohearchai
Washington
Martin
V1500 Suburban
Well I blew out the line running to the tbi, changed the inline filter even though it looked good, checked the fuel pressure, all was good. Got in, turned the key and she fired up after a few turns. Thanks for all the ideas guys, she's running and that's all that counts.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
Glad you got it running - with thing like this I always like to figure out what actually went wrong so the next time I know where to start looking.
If your pump sock is getting clogged by debris in the tank,it will probably happen again. So be prepared. Depending on how big a deal the piece if mind is to you,you may want to drop and clean out the tank.
Chevy 88
Canada
f7t6
GMC
Fuel tank under vacuum, starving the fuel system? Test: Drive with fuel cap loose or removed.
Sad Sack
Nebraska
Goober
C15
Or just replace it...
jw23655
