Rally wheel resto
speedy
MS
Brandon
Hey guys. So i have been thinking about going back with 15's on the 82. I have a set but one is in bad shape. It has rust and pitting where the tire bead seats. It's all around on both sides. I tried to clean a little but curious on how I need to continue. Anyone have any experience with this?
This is what I have going on
Is this even worth repairing?
J Knight
Baytown TX
82 Chevy
350ci
Rally wheels are so cheap, I think I would replace the one or two badly pitted wheels, the one pictured would probably leak.
Moderator
A little time with a good wire wheel in a drill would smooth that out. Or a flap wheel in a grinder, just need to be a little more careful. Looks like there's more buildup than there is pitting. Once it feels smooth (but probably still some pitting) it will be ready for some bead sealer and a tire.
speedy
MS
Brandon
Yeah there's cancer all the way around and on both sides. I'm just going to find another wheel so I won't have any issues in the future.
I may consider a pair of those 15x10s. Not sure what backspacing I need to clear with my drop. I have a flip kit and 2" drop shackles. I believe the 20x9 camaro wheels + 1.75" adapters I have on now, is around 5" and they clear just fine. Any ideas?
J Knight
Baytown TX
82 Chevy
350ci
15x10 with 5in backspace will clear with no problem.
speedy
MS
Brandon
Good deal. Thanks for the help
speedy
MS
Brandon
Well after pricing those 15x10s, they are a little out of my budget for the moment. So I just ended up repairing the 2 wheels I started on to begin with. They turned out pretty good I think. I used a high build epoxy primer and sealer primer. Test mounted the tires for 3 days and they didn't leak at all. I then used a base coat, and clear coat over the entire wheel. I'm happy with them. 2 down, 2 to go.
74 Shortbed
They look good..
johnnieb
Nevada
john
350 Goodwrench/replaced 6.2
I just found a set of 15x8s I'm going to put them back to work with a set of 32x11.5s, I like the rallys.
speedy
MS
Brandon
Thanks. You just can't beat the look of the rallys.
speedy
MS
Brandon
Does anyone know if I will need the standard or the 2" valve stems to go through the beauty ring?
Sent from my SM-G925R7 using Tapatalk
speedy
MS
Brandon
I just realized i never posted a follow up pic but posted one on another thread. They turned out nice. I ended up putting some 295/55 Mickey Thompson ET streets on the back. Clear with no issues.
Ill eventually go with the 10" rally. Im getting things together to have a 25x30 metal building built. So play money is on hold right now. But after thats done ill be starting on the body work and maybe by next year ill have a nice pickup.
Scrambler-Cafe
