Quadrajet too rich!
DemarioM
Aurora
Demario
Good evening. I have an 85 c10 with a 305 in it. It's my dream since I was a child. The carburetor I've got is I quadrajet 17085226. I'm inquiring because I'm having a hard time passing emissions due to it's running too rich and, I don't know what else I can do to correct it. I'm pretty sure at this point I just need to change the jets due to the altitude. I live in Aurora Colorado and the altitude is 5,403 ft. I need help purchasing the correct jets. I'd really like be able to drive my dream truck legit but I can't get a registration until I pass emissions.
PLEASE HELP!
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
PLEASE HELP!
to rich at idle cruise or acceleration? do you have a copy of your emissions test it would help
DemarioM
Aurora
Demario
I have about 7 copies, the best I've done so far is..
HC 4.7O
LIMIT : 4.5
CO 90.03
LIMIT : 45.00
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
HC 4.7O
LIMIT : 4.5
CO 90.03
LIMIT : 45.00
are these idle readings or do they do a dyno run and take reading?
DemarioM
Aurora
Demario
These are on a dyno
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
These are on a dyno
OK things that's can cause hi CO and HC under load
problems with the ignition system causing a miss under load. plugs use only stock type plugs nothing fancy, no platinum's , no iridium's , no multi tipped plugs they are just going to cause you problems. check you plug wires , I like to use a spray bottle and mist the plug wire if there is a bad spot in the wire you will get an audible tick and drop a cylinder. Also make sure your mechanical advance is working.
If your ignition system is good and it is a carb problem . things to look at are float level to high will go rich, primary rods bent, power piston stuck, mains jets too big. If it is a carb issue I would build it by the book first before changing jets or any think else.
the books are here https://www.gmsquarebody.com/threads/1973-1991-service-manuals.14499/
bob seifert
missouri
bob
Your carb 17085226 has a solinoid in it to cause a double pump in the idle circuit when cold. If its stuck open that maybe the problem.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
emissions on a 30 something year truck??? WTF?? move to a friendlier state.
Couple of things come to mind, check for vacuum/ intake leaks. Make sure all your vacuum hoses are routed correctly that truck should have like 0 advance at idle from an emissions stand point so a failed tvs, improperly routed vacuum line etc. can cause you to fail.Pull some timing out and fill up with 10 percent ethanol fuel just for the emissions test.
SirRobyn0
Rob
The above is great advice. Ricko, talks about timing, yes it would be a great idea to set it with a timing light, I'd only retard the timing for the purposes of getting it though emissions if everything else checks out first, but that is me.
squarelyfe
NORCAL USA
Larry
k25
It's a 750 cfm carb on a 305... It's a little rich to begin with. Get yourself a Holley 600 cfm or Edelbrock if you can pass smog with one of those. Lean the af mixtures in and check timing.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Check for leaking well plugs. Simple fix, but can lead to uncontrolled extra fuel in the system.
Scandia
