Quadrajet Spacers
Mlcdc1
IN
Running a 1977 C15 stock 350, 4 barrel quadrajet and having issues with heat soak. Considering a carb spacer, wondering if that’s an option and if so what recommendations anybody has. Thanks.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I also like the thick gaskets. Never had a problem from them.
Mlcdc1
IN
Any recommendations on brand and type. If I read things right, there are a lot of different materials they’re made with.
Moderator
Just the stock type thick one.
Just get the stock mounting gasket,Look it up in a parts catalog,they aren't all open center as @bucket pictured but they should all be thick and act as an insulator. The difference between an open center and a 4 hole is the open center will act like an open plenum on a car designed for a 4 hole.
Moderator
Yes, there are 4-hole versions that were used by GM as well. The only reason I posted the open plenum version is because that's what Autozone showed as correct for a '77 when I looked it up.
I was just stating for GP there were both to the OP,you went the extra mile and looked it up by application. Thanks,Merry Christmas
fast 99
Spokane, Washington
Hot soak issues have been around since the EPA started messing with fuel.
My SB's do start a bit hard after hot soak. Not horrible but noticeable. To help I buy highest octane E free available. That's lower than regular was when these trucks were new. One doesn't have a cat so I add a little AV gas [1 or 2 gallons] to a tank during the hottest part of summer. That does help and exhaust smells nice.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
If you want more than just the thick gasket, look for a q-jet heat shield, GM pn 3969837.
(Quick pic from the net, as I’m not home at moment)
olnick
Milford NH
Nick
c15
1982 350 4 bolt mains
I mentioned the final solution to the problem in a fuel pump posting! The ultimate problem is not the heat but the excessive PSI provided by ALL the aftermarket pumps. My solution is to get a Holly F/p that is able to be dissembled (I don't remember the mod #) and REDUCE the operating PSI by reducing the spring length to provide ~ 5 psi output. F/P mod # is listed in attachment!
Drap
Ryegate Montana
I don't really get how "heat soak"works. Those little vents and stuff in the bowl are actually kind of important
Fat 454
Australia
C20 Suburban
Heat soak is what happens when your engine has run up to operating temperature ( hot ) and is then shut off. The cooling effects of the circulating coolant, air flow and fuel flow all stop, and the heat from the engines combustion looks to escape through radiation. This takes time, and the engine's external parts heat up as the heat is transferred outward. Aluminum is a great heat conductor ( as in an aftermarket intake manifold and your carb body ) and therefore heat is conducted up into the body of the carb. The Q jet has a small centrally located fuel bowl, all nicely insulated and surrounded by radiant heat. As the heat increases, the fuel in the bowl boils away. When you come to re-start, you have to crank the mechanical pump over ( if you don't have an aftermarket electric pump ) to get fuel back into the bowl and re-start.
Resin block insulators are good, as they have a higher insulation effect then just a gasket. They will also raise the carb by a corresponding amount, so check you will have enough hood clearance. A large single central hole will also act like fitting a tunnel ram ( ie more flow at high rpm ( 4,500 upwards ) and boggy at low "driving rpm ( 1,500 - 3000). An insulator with the 4 holes would help, however make sure they fit your secondaries ( ie spreadbore to match the carb, not squarebore ). You may need to re-jet also.
The fuel supply / return is also important. As mentioned check your fuel pressure, fitting an inline gauge next to the carb will help. Also consider both an electric pump ( eliminates cranking on re-start ), and a return valve that will manage and prevent any vapour lock when it is hot and left standing.
Experimentation is your friend, as everyone's set up and driving needs are different.
Please post any changes you make, and the resulting effect. Will be interesting to know.
I am planning to experiment with both the new Edelbrock AVS II, and a re-built thermoquad for both around town driveability and moderate performance.
Cheers - A.
59840Surfer
Montana
Joe
Q-Jets also have well-plug leaks.
There is a kit --- maybe not anymore 'cause they were obsoleted a while back - but someone has them --- called "Home Plate" by Tomco that sealed the well plugs so they wouldn't leak the fuel from the float bowl. Resist the urge to use JB Weld - it is hard to remove later. Seen it - many times.
There are a few reasons why Q-Jets are hard to restart after a hot soak.
1) The check valve in the inlet filter is missing
2) The well plugs are leaking
3) The gas is boiling out from the metal heated by conduction from the manifold ------
------ usually because performer QJets don't have an ECS Vent Valve.
One more consideration is if the fuel pump is the original style pump mounted on the engine block, operated by the pushrod that rides on the cam.
There should NOT be a drain-back problem because of the pump - because it is supposed to have a check valve - but this type of fuel pump sucks from the fuel tank and any time fuel goes into a slight vacuum, it boils easier and that can form gas bubbles in the fuel line.
------- that is called: vapor lock.
I mount an electric pusher pump as far back and near the tank as I can, sometimes even two. I haven’t had vapor lock in decades.
If it is a 3 port pump there is no check valve in the return line,they will drain back through the return line, if you have a windowed needle and seat and a missing or inop fuel filter check valve. Not always but way more likely than if you had a solid needle and seat.If a little gas evaporates the float drops,the needle opens and the fuel drains all the way to the float bowl floor,instead of just to the top of the non windowed seat.
Scrambler-Cafe
