quadrajet heat soak
WFO
Texas Panhandle
My fuel pump does not have a 3rd port, and I believe those didn't come with a return at that time, I beleive GM started implementing a return in the mid-late 70s, but I don't think it would take much for a guy to add a return
You didn't say what year your Chevelle is, but my 69 SS has a return line.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I can say that I have ran a lot of non-return line vehicles and they didn't have issues with heat soak or vapor lock, and I ran them in all weather conditions and elevations. I will agree with what was mentioned, your timing is probably too advanced. Wouldn't hurt to check the well plugs, and other things mentioned, but if it were me, I'd adjust the timing first then go from there.
77Dmax
vt
Joe
How many times are you pumping it before trying to start it?
Also pull the air cleaner lid and see where the choke is at with your next hot start. It should still be wide open. If it's closed than it's adjusted way too tight.
Sam71395
Minnesota
Sam
V10 Silverado
its a 69 malibu, sorry I should have clarified, could it be possible small blocks didn't have a return, because I looked it over pretty closely and can't find any evidence that a return line was ever there, would not take much to add one
Sam71395
Minnesota
Sam
V10 Silverado
You may be on to somthing, I do recall that if it sits for a little bit (10-15min) when it's warm and I go and start it again, the high idle kicks on for about 30 seconds, so that means the choke would be closing again, I will adjust it today
Drap
Ryegate Montana
IF you've had a back fire, the power valve could be stuck open and is dumping raw fuel into the maniflod
77Dmax
vt
Joe
That's probably it, your choke is way to tight. When the motor is cold you want to turn it until the choke fully closes, no more. No need to preload the spring or anything like that- just enough for the blade to close. That should get you in the park.
Sam71395
Minnesota
Sam
V10 Silverado
Ok just got done driving it, I let it sit for about 20 minutes and went to restart it again, and it was significantly better, I still was an extended cranking time but it did not seem like it was flooded this time, this seemed like the fuel bowl was empty more than anything.
77Dmax
vt
Joe
Good deal, keep tweaking it!
Yep will do, thank you all for the help
Next time you let it sit,before you crank it pull off the air cleaner,look down the throat of the carb see if it's dry,it should be That's how I discovered the problem on mine,mine was soaked,I put a return style pump on and the problem went away.
Sam71395
Minnesota
Sam
V10 Silverado
I will do that, if I have the same problem would one of those fuel filters with a 3rd port (like a wix 33041) act the same way as a return style fuel pump?
Yep.
duncan_schawalder
