Q-Jet with divorced choke question.
DanMcG
Central NY
k10 k10
I picked up a 72 dated carb and manifold for cheap thinking I could the choke set up on my 78 which doesn't have a choke. Well the 78 doesn't have the pad on the manifold to mount it either. I really don't want to swap manifolds for just a choke. I wondering if there is a way to mount an electric choke.
Just to add info, the exiting carb in the 78 I think is original, but the motor is out of an 86 I beleive. 4 bbl. 350.
I've got a manual choke cable but really don't want to use it.
Thanks
legopnuematic
Licensed Junk Dealer
MO
Spencer
Does your manifold have the provision for a hot air choke or nothing for an electric application? You should get able to adapt an electric cool to a hot air q-jet
Sent from my Moto Z (2) using Tapatalk
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Don't they make an electric choke for a Quad?
350 w/203
Yes. Mine has one. It works very well.
DanMcG
Central NY
k10 k10
It has nothing for any type of choke.
Well Duh! I was reading that an electric choke won't mount to the old style carb. I guess I'll have to tear it apart and take a better look.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
If the carb your working with has the round choke heater on the passenger side, you can easily convert to an electric choke. Remove the factory hot air style heater, remove the gasket, ideally you should remove the hot air tubes (you can leave the heater part I the manifold) and block the small internal vacuum port in the back of the housing. Then install the electric heater (make sure you remove the gasket, it grounds thru the housing). With the engine cold, press the gas pedal, the choke plate should close. Rotate the heater until there is a slight tension holding the plate closed. Then, use a hand vacuum pump to apply vacuum to the choke pull off. The choke plate should open a little. The exact amount it opens varies by engine, options, year, etc. Apply SLIGHT closing pressure to the choke plate (to eliminate slop in the linkage messing with your adjustment) and adjust the serscrew on the pull off to open the choke about 3/16 inch. Disconnect the vacuum pump, the choke should fully close again. Reinstall the pull off vacuum hose, start the engine. The choke pull off should open the choke plate slightly. As the engine runs, the choke should continue to open. After a few minutes, the choke should be fully open. You may need a few cold starts to dial in the “happy place” with the choke pull off. If it starts and then almost immediately begins to load up and puff black smoke from the exhaust, the engine needs a little more air, adjust the pull off screw to open the choke plate a little more. If it starts, then dies, or dies when you put it in gear, or dies when you try to accelerate (engine is lean) the choke plate may need to be closed a little more. Like I said, it may take several cold starts to get it right.
Once the engine is fully warmed up, then adjust idle mixture. With the engine off, lightly seat both mixture screws, then back them out evenly about 2 1/2 turns. Start the engine, pick one mixture screw, turn it in out out about half a turn. Pay close attention to the idle speed, hopefully you can detect a change in speed. The idea is to adjust the mixture screws evenly until you have the highest idle speed. Once that’s done, reset idle speed wherever it’s desire, then readjust the mixture screws again, going maybe 1/8 turn at a time. Once that’s done hopefully it idles smoothly, at a low enough speed, and doesn’t die when you put it in gear. Good luck!!
ronscoms66
