put one e fans runs hotter
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
So I put e fans on now it runs hotter driving down the freeway..245' but cools fast when stoped back down to 200'. Timings at 11 btdc you think that could cause it to run hot...before it ran fine down freeway but got hot sittin.. idk fml cant win
350runner
tx
Ceasar
Kinda sounds like there is something slowing the air flow at highway speeds.Did you ever recurve your distributor?
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
No I didnt recurve it looked in to it though. Now I had my vac advance hooked up to manifold port on the edel I just switchd it to timing port it droped my idle down to 5-600 . Do I have to reset my timing on the right port or will it be the same and just advance slower
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
The shop next to my wrk thinks the lower 1/4 of the rad might be pluged they said to put a new one in and see..I dont want to spend 400 to SEE if it fixes it.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Is it possible that on the freeway with the fans on they are blocking air flow. Should they be off and free spin
rich weyand
Bloomington Indiana
Rich
All putting it on timed vacuum will do is give it a crummy idle and an off-idle throttle response lag. It won't make any difference in driving, just in idle.
rich weyand
Bloomington Indiana
Rich
They should help if running, compared to pinwheeling.
Is it a pusher or puller? Shrouded or not? SBC or BBC?
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Iv 454 ford windstar fans that are on I can tell on my volt gauge. . Twin Pullers in shroud
rich weyand
Bloomington Indiana
Rich
You need a bigger alternator if you can see that the fan is on by your voltage gauge. The alternator should lock in the regulator and hold voltage all the time. Low voltage to the fans will reduce the air flow by the square of the voltage drop. 10% voltage drop, that's 20% less air.
What kind of alternator is on it? How many amp? Does the alternator have the stamped steel fan on the front behind the pulley, or does it have a flat steel plate with a black epoxy turbine style fan?
Do you have a four-row radiator or a three-row radiator?
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Four core rad black plastic alt fan maybe 70 amp
DesertK20
Derek
SBC
My '69 Mustang had overheating issues after I switched to a twin fan/shroud. I switched it back to the motor driven clutch fan and, after cleaning the radiator, no more issues.
Pull the radiator, fill it with 50/50 muriatic acid (found at pool supply stores) and water, let it bubble and cook for 15 minutes. Should unclog it easily.
I was once told that those fans should free spin while on the freeway and could impede airflow. Could be wrong?
While the fan is running you should be able to put a piece of paper over the front of the radiator and it'll stick.
rich weyand
Bloomington Indiana
Rich
Black plastic fan means it's a 12SI. 75 amps or better. You can get 12SI alternators and aftermarket replacements to 130 amps. I would put a 94-amp 12SI on there as a minimum. You need to keep your voltage from sagging at any rpm above idle.
350runner
tx
Ceasar
When you upgrade the alternator also Do the big 3 with at least a 4 gauge wire from the alternator to the bat
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Ive done the big three already... as for alt im gathering parts for a serpentine just need reverse water pump and smog pump then ill put it on and use a 92 chevy alt 130..ill try putting a kill switch in it while driving and see if it unblocks it
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Its sucking plenty air sitting idling you can feel it in front of the grill..
sever
