Pulling to the right when braking...
350runner
tx
Ceasar
Trucks done it since I got it.... had new rotors and pads. Just replace a perfectly "looking like brand new" rotor that was warped... What could it be? Hoses? Caliber? There's no dragging and all front end suspension parts been replaced. Thanks
Skweegle89
Oklahoma
Pulling to the right when breaking...
How old is the power steering pump?
350runner
tx
Ceasar
Prob as old as the truck. It does pull to the right when driving as well.
Smith
NW Ohio
No
any air in the lines and bled properly? possible collapsing or pinched line that is releasing pressure slower? Unevene lines?
350runner
tx
Ceasar
I've never bled the lines as I've never opened them up. I guess I could give that a shot. The hoses are originals.
Skweegle89
Oklahoma
I bet you a dollar to a donut that it's the PS pump. It doesn't seem logical, but if it's not a brake/rotor problem, 9 times out of 10 it will stop if you replace the pump.
350runner
tx
Ceasar
I don't noticed any pinched lines. tho they could be clasped inside.
350runner
tx
Ceasar
I'm wrong it's Pulling to the left while breaking to the right while driving...
Perhaps the right brake hose is restricted or closed shut? A crack of the bleed screw would tell.
350runner
tx
Ceasar
Good idea! I'll go out and get some more fluid tomorrow
When it pulls does it feel like the steering wheel is getting yanked out of your hands or is it like the whole truck just pulls. That should narrow it down to front or rear brakes/suspension.
350runner
tx
Ceasar
Well if it's cold out it'll tank the steering to the left. After it's fine wanted up it very little.
350runner
tx
Ceasar
That worn rotor coulda wore out the new suspension parts on that side tho... Idk. After the new s parts I rode bout a couple months b4 I had time to change the rotor :-(
jchance
oxford ms
jeremy
1500 4x4
If steering wheel is pulling hard right and you have replaced the steering pump whats your next suggestion?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Jack the front end up and check the steering sytem for wear like the pitman arm and the tie rod ends going to the spindles for movement. You wiggle the tires side to side and up and down.
sallyjeank10
